upgrade path
  • EcoStruxure IT forum
  • upgrade path
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:32 AM . Last Modified: ‎2024-04-08 11:18 PM
907
upgrade path
error (2).zip
(CID:108235108)
Replies 7
Hello, To better answer your question, please provide your current version and what version you are looking to upgrade too. Thanks Victor
(CID:108235110)
Hi. Sorry did not realize I had hit send so soon. Sorry for that. I am trying to upgrade virtual DCE 7.2.6 to 7.2.7 and it seems to finish phase 1 but after the restart the server starts with an error indicating it can not access its data in the webpage and I am unable to log in with the client. Like some database services do not start correctly. After I am restart the virtual machine the server starts normally but always in DCE 7.2.6.
It never seems to start the upgrade phase 2 after the restart in phase 1.
Thanks and regards
Saethor
(CID:108824301)
Posted: ‎2020-07-03 05:33 AM . Last Modified: ‎2024-04-08 11:18 PM
906
Hello, It sounds like something may have gotten corrupted during the upgrade. Do you have a backup that was made prior to attempting the upgrade to 7.2.7? If so, I would recommend restoring the server to 7.2.6, import the backup and then upgrade to 7.2.7. This way we are starting for an untouched clean know working state. I would also recommend run an MD5 checksum to ensure that the download is good. You can use WinMD5 which is a free download. Thanks Victor
(CID:108824300)
Hi Sæþór Jónsson, did you get the upgrade to work? Best regards Ditte
(CID:108824302)
Hi. I both tested the upgrade file on a new VM expert and that worked fine. I also did a new restore on the VM from before a week before I started the original upgrade and I still have the same issue. It seems like the some files are corrupt or some service does not start after the first reboot during the upgrade. I may have to recreate a VM from scratch and use config backup to get this running normally.
(CID:108824308)
Hi. I have uploaded files after my last upgrade test. Both the log files and some snapshot. Can these files give any idea why the upgrade fails? Thanks and kind regards Saethor
(CID:108824794)
Posted: ‎2020-07-03 05:33 AM . Last Modified: ‎2023-10-31 11:40 PM
