sun blade 8000
  • EcoStruxure IT forum
  • sun blade 8000
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 03:13 PM . Last Modified: ‎2024-04-09 03:55 AM
607
sun blade 8000
In DCO, is there a blade that will fit in a Sun Blade 8000 ?
(CID:101027929)
  • Data Center Operation
606
Hi Michael,
It looks like there is an error in the Genome library for this Sun Blade 8000 enclosure.
Here is a how to modify the properties so you can use the blade enclosure.
  1. After you have added the enclosure to the Genomes right click and select Properties.
  2. Now click on Physical
  3. Change the Amounts of bays to 10
  4. Click Ok
  5. Add the blade enclosure to the rack
  6. In the Genome Library locate the blade Sun Blade X8400 Server
  7. Add this to Genomes
  8. Right click and select properties
  9. Select General
  10. Under Family write Sun Blade 8000
  11. Click OK
  12. Now you should be able to add the blade to the balde enclosure.
Jesper
(CID:101027975)
Replies 4
607
Hi Michael,
  4. Click Ok
  9. Select General
  11. Click OK
Jesper
(CID:101027975)
(CID:101613574)
I have reported this issue to the development team so it can be fixed in one of the upcoming releases of Data Center Operation.
(CID:101613658)
Posted: ‎2020-07-02 03:13 PM . Last Modified: ‎2023-10-31 11:37 PM
