Posted: 2020-07-02 03:12 PM . Last Modified: 2024-04-09 03:56 AM
Hi ,
I have one question about DCO VIZOR . Below are the photo for reference .
customer can not see the estimated load from rPDU which I already connect the power from rPDU to
server .What's the problem for this case ? Your help would be appreciate.
Best Regards
(CID:101027904)
The Vizor application has not been updated in a while. It seems like you have encountered a bug in Vizor as the "estimated load" should only be visible on Servers and not on Rack Mount PDU's.
In Vizor the term "Estimated load" corresponds to "Adjusted nameplate" in Data Center Operation. And should only be visible on Servers. It is really not optimal - and we will change it in a future version so it is easier to understand.
Why you are seeing "Estimated load" on the rack mount PDU is a bit of a mystery to me. Could you help me understanding what kind of rack mount PDU you are using? e.g. the part number. Then we can investigate why you are seeing "estimated load" as this should only be visible on servers.
Best regards
Anders
(CID:101613626)
Hi Chu Li Wei - did you see this?
(CID:102236201)
Posted: 2020-07-02 03:12 PM . Last Modified: 2024-04-09 03:55 AM
Hi Anders, Thanks for your help , I just put a basic 1U rPDU in AP95XX series in DCO . Above info for your reference , many thanks . Best Regards
(CID:102236339)
Posted: 2020-07-02 03:13 PM . Last Modified: 2023-10-31 11:33 PM
