Posted: β2020-07-03 03:06 PM . Last Modified: β2024-04-08 01:05 AM
I'm trying to restore my backup and I get to the point where it's listing backups but it doesn't list anything for me to restore. It'll ask me to select a back number for restore from 0-quit. When I punch in 0 it exits out.
My command is 'apolloRestore.bat restore -mntType WINDOWS_SHARE -server 127.0.0.1 -dir backup -share c$'
My backup is located in C:\backup and the file is called drive-download-20170411T215017Z-001.
Could someone ID where it's breaking?
update: I am see more error saying SmbFileSystem:190 - Chnage directory Exception: Logon Failure: unknown user name or bad password.
I'm putting in every user name and password I know of for this setup.
(CID:116919805)
Posted: β2020-07-03 03:07 PM . Last Modified: β2024-04-08 01:05 AM
fixed: the new command I put in is:
apolloRestore.bat restore -mntType WINDOWS_SHARE -server 127.0.0.1 -dir backup -share c$ -user Administrator -pw -domin ./
(CID:116919825)
(CID:116919825)
Hi eric.yue,
I.e., can we assume, that the problem is solved? If so, please mark it as solved.
With best regards.
(CID:116919929)
Posted: β2020-07-03 03:07 PM . Last Modified: β2023-10-22 09:36 PM
