Posted: 2020-07-03 03:07 PM . Last Modified: 2024-04-08 01:05 AM
Hi support Team,
(CID:116919986)
Posted: 2020-07-03 03:08 PM . Last Modified: 2024-04-08 01:05 AM
Hi mamacoo,
After DCE-server rebooting, you can login to the DCE Web-console?
How long have you been interested in the size of the available disk space on the DCE-server?
If this is DCE VM appliance, try adding one more virtual HDD of the size, for example, 50GB. Power off and power on the DCE VM appliance after that: if the server software is OK, then the newly added amount of free space will be added to the /data logical volume and the server software should start normally.
I am always glad to help.
(CID:116920008)
You need to adjust the available harddisk space on the virtual machine in order to make more space available.
Attention: do not increase the size of an existing virtual HDD. This will not help you. It is necessary to add one more separate virtual HDD and restart the DCE-server. This rule applies to both the DCE VM appliance and the DCE hardware appliance. Look carefully at this topic: .
With best regards.
(CID:116922529)
Hi Spezialist,
the /data is 100% load,how to add free space to the /Data Folder?
(CID:116920127)
mamacoo,
See my answer below:
(CID:116922527)
Posted: 2020-07-03 03:08 PM . Last Modified: 2024-04-08 01:04 AM
yes,i get it.,add a second vhdd or extend the /data can resolve it.Thanks
(CID:116924062)
Hi mamacoo,
By adding the second vhdd, you thereby expand the automatically /data partition.
But simply extend an existing /data partition without adding a second vhdd is no longer so easy, since you either need the root password, or mount the DCE-server partitions offline with a Linux LiveCD 😀.
With best regadrs.
(CID:116924103)
Posted: 2020-07-03 03:08 PM . Last Modified: 2023-10-22 01:10 AM
