Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 04:33 PM . Last Modified: 2024-04-08 12:35 AM
We have DCO 8.1 and searching for gnomes is difficult.
Example searching for AP8888. Yes, AP8888 is in both libraries. When I type in 8888 or 888, the search does not list anything. It will list the AP8888 genome in the global genome library. If I type just 88, then all devices with 88 in the name are listed including the AP8888. This happens when searching other devices also.
(CID:119638162)
Hi Tim,
I have added AP8888 to my Genomes (from Genome Library), and when I type 8888 in the Search box, then my search is successful both for Genome and Genome Library:
would you mind to share a screen capture illustrating the issue, thanks.
Kind regards
(CID:120129554)
Posted: 2020-07-03 04:34 PM . Last Modified: 2024-04-08 12:35 AM
Hi Tim (Tim Polnow)
The cause of the Genome search issue is now located in your kindly provided solution. In the custom catalog there is a bundle without name.
As illustrated, if we assign a name to bundle in the category Genomes -> Storage -> Spectra Logic, then we will be able to search again:
Kind regards
(CID:120132447)
Posted: 2020-07-03 04:34 PM . Last Modified: 2023-10-22 09:36 PM
