Posted: β2020-07-03 07:39 AM . Last Modified: β2024-04-08 04:07 AM
I have a customer who wants to swap out a Netbotz 500 unit for the Netbotz 570? Is this an easy swap out and do the configs on 500 model compatible with Netbotz 570? Or is it a complete new configuration?
(CID:110004238)
Hi Gary,
The 570 will work with the older camera and sensor pods. If you have sensors plugged into the 500's docked pod, you may want to un-dock it and connect it to the 570 via USB as the older sensors can't directly connect to the 570, the need the sensor pod.
You can not take a backup (configuration) from one NetBotz appliance and import it to another. As noted in k-base FA176136, the sensor and pod IDs are dynamic so the config can not associate the sensors. You'll have to manually configure the 570.
(CID:110004240)
Hi Gary,
(CID:110004240)
Thank you for feed back Steven
(CID:110004338)
Hi Steve,
Dow this still apply if we keep that same other Netbotz 150 and sensors all with the same OID in the configuration??
Matthew
(CID:136645326)
Posted: β2020-07-03 07:39 AM . Last Modified: β2023-10-22 09:35 PM
