Posted: 2021-05-04 04:58 AM
We are having problems in our data center in Argentina, when we activate the proxy suddenly the netbotz 355/570 lose communication:
( see img 1)
It is seen that after re-activating the Proxy when it polls them again it can no longer:
(see img 2)
When we left it operational with the proxy connected, all the equipment looked fine,
but now when entering we see that they are with that alarm ... I tried to remove the
proxy (nothing), I put it back (nothing), but the strange thing is that the GW reaches out
to apliances to survey their components and states:
(see img 3 and 4)
what can we do now to communicate them again? where could be the problem?
Posted: 2021-08-17 07:37 AM
Hi @cristian,
Since you haven't received an answer here in the forum, you can go to https://ecostruxureit.com/support and open a ticket if you haven't already resolved this issue.
Best,
Jackie
Posted: 2021-08-18 01:44 AM . Last Modified: 2021-08-19 02:07 AM
EcoStruxure IT Expert provides partners with a multi-tenant monitoring solution for vendor-neutral, secure visibility across multiple customer sites. Add power and cooling monitoring into your service contracts, or simply resell this software as a service to your customers.
