We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Posted: 2020-07-04 10:45 PM . Last Modified: 2024-04-04 02:47 AM
Hello community,
Our customer has pdu's connected with Network Port Sharing. Some of them are stuck at Firmware Upgrade screen as you can see in the picture below. I solve some of them after resetting the PDU, however, some of them are still not upgrading their firmware.
SOme of the PDU's are stuck in blue screen as you can see in the picture below. I can't reset these PDU's.
What should I do? Do have to send these PDU to hardware service?Do I have any other option?
Thanks in advance,
(CID:134026446)
Hello Erhan,
You can check this knowledge base article, lots of tips & tricks you can try:
http://www.apc.com/nl/en/faqs/index?page=content&id=FA293874
and this one contains more details about the network port sharing:
regards,
Cees
(CID:134026521)
Hi, I would answer sooner, but I was unabled.
I had similar issues after firmware update with 2 PDU`s two months ago & nothing we did solved the problem. We had to replace both of the PDU`s.
We were unable to connect to the PDU through any known protocol, so our conlusion is that the firmware update didn`t pass. After last few times we decided not to update any more firmware`s on PDU devices unless we have replacments in stock & the client has a long down time period for DC.
(CID:134027632)
Dear Erhan Yasar,
Tell us, please, did you solve your problem or not?
With respect.
(CID:134680070)
Posted: 2020-07-04 10:45 PM . Last Modified: 2023-10-22 09:34 PM
