Netbotz 570 + Pod
  • Netbotz 570 + Pod
126
65
Posted: ‎2020-07-04 10:44 PM . Last Modified: ‎2024-04-04 02:47 AM
997
Netbotz 570 + Pod
Hi
i'm having an issue with a customer with this configuration
  • 1 NetBotz 570
  • 9 Pod 150
  • 1 AP9520TH
Connected with A-link and the last one is AP9520TH
i have also a power supply in the middle (on a pod 150)
On pods 150 there are connected also dry contact and TH sensor
as you can see on the image below, (humidity sensor) netbotz lost a lot of data.
Temperature sensor is working fine but Humidity sensor is  unavailable.
i have also change sensors, pods, configuration but nothing change.
any help?
(CID:134026388)
  • NetBotz
Hi Gianluca Bertuletti, thanks for posting!
Let's hope you find your answer here.
Stine
(CID:134029009)
I recommend reaching out through your local technical support / technical escalation channel to have this investigated.
Kind Regards,
Cory
(CID:134029719)
Posted: ‎2020-07-04 10:45 PM . Last Modified: ‎2023-10-22 03:20 AM
