We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on
Cloud Connected vs On-Premise Services. Your feedback can
help us shape the future of services.
Learn more about the survey
or
Click here to Launch the survey
Schneider Electric Services Innovation Team!
Posted: 2020-07-02 09:53 PM . Last Modified: 2024-04-09 01:38 AM
I cannot find an on/off switch on the netbotz appliance - is there a specific way to power it up. I removed the power cable waited a while then reconnected the power but it will not switch on.
(CID:105459485)
Dear Riyaad,
There is no On/Off switch on the appliance.
The Netbotz should power ON as soon as the Power is supplied.
There is a Power ON Green LED which should lit after the power is fed to the appliance. Please make sure that the Power Cord is not faulty. Try checking the appliance with a known source and working power cord.
If it still not powering ON, then appliance could be faulty. Please contact country technical support if its under warranty.
Bala
(CID:105459501)
Dear Riyaad,
NetBotz 500 is powered by the below APC Dual Power Supply, -5V/3.3V adapter, you may want to check if it's also working.
Felix
(CID:105459518)
if you have another netbotz 500 on hand, perhaps you could try swapping this power supply with a known working one.
(CID:105459581)
Posted: 2020-07-02 09:53 PM . Last Modified: 2023-10-31 11:25 PM
