Posted: 2020-07-05 02:25 PM . Last Modified: 2024-04-03 11:55 PM
How do I do a factory reset on a netbotz250?
I don't see any field under the network tab with that option, and the help manual does't help also.
Thanks.
Ricardo
(CID:136644577)
Dear Ricardo,
Are you looking for this option?
(CID:136644585)
Hello Balaraman,
Thanks for the answer, I was looking at that, but it doesn't work, I suspect I have a hardware failure.
Ricardo.
(CID:137108871)
Hi Ricardo,
Good day!
If the steps described by Bala did not seem to help. You can issue a telnet/SSH command on the NMC to reset it to defaults.
apc>resettodef ? Usage: resetToDef -- Configuration Options resetToDef -p
If this still does not help, deleting the database manually and/or issuing a format command can also be done via telnet or SSH to wipe the flash memory and any remaining configurations including your current TCP/IP settings.
The instructions are explained in detail from the article from the link below:
https://www.schneider-electric.us/en/faqs/FA175980/
I hope this helps.
Kind regards,
Justine Chester
(CID:136644876)
Hi Ricardo, In addition to Justin's answer, I suggest to make sure that you are using the administrator user name and password when you are doing the steps. It is most likely not related to hardware issue.
(CID:137108873)
Posted: 2020-07-05 02:25 PM . Last Modified: 2023-10-22 09:32 PM
