missing work orders
  • EcoStruxure IT forum
  • missing work orders
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 03:14 PM . Last Modified: ‎2024-04-03 11:30 PM
1190
missing work orders
Although not a massive priority, we have noticed that some work orders appear to be missing.  These were not we believe actually created by anyone, in other words there are work order numbers - sequentially missing - but not work orders.  Is there a known reason for this occurrence?
Nigel
(CID:137110432)
  • Data Center Operation
1190
Hi Nigel,
Many thanks for providing the data - the "missing" work order numbers seems to be reserved numbers that are not used. When starting a task/work order, work order number may be reserved - so it seems the non existing work orders are the reserved, but not saved work orders (eg. closed without saving).
Kind regards
(CID:137725699)
Replies 5
Hi Nigel,
Can you please upload the following data to our shared space, then I will look into it:
screen capture(s), illustrating what you are seeing on the screen.
copy of the latest backup file (containing the issue)
server logs
client application.log file.
Kind regards
(CID:137110443)
1191
Hi Nigel,
Kind regards
(CID:137725699)
Thanks Jef.  I always thought that if a work order was started but then closed - or DCO closed without saving - then a work order number would not be assigned.  I only though work order numbers were assigned at the point of 'save'.  Therefore there should not be 'reserved' numbers?
(CID:137725794)
Hi Nigel,
You are most welcome - behind the scenes creating a work order initiates "taking/reserving" a work order number. Reserved number can/may be released if not used, however not releasing the number may also be expected specially in a multi-user environment.
Kind regards
(CID:137725806)
Posted: ‎2020-07-05 03:14 PM . Last Modified: ‎2023-10-22 04:42 AM
