Posted: 2020-07-03 12:44 PM . Last Modified: 2024-04-08 01:51 AM
Hello community
I want to kwow how to use the genome Mesh wall in a room.
I need to put one between rwo raw in a little room
tks a lot
Best regards
Rocchino
(CID:111413414)
Hi Rocchino,
I would try to enable and use the "Draw wall" tool, and draw a wall, and then define its material in the wall properties "Physical" tab, as illustrated here:
that's it. Here is a 3D view of the wall:
Kind regards
(CID:111413431)
Hi Rocchino,
Kind regards
(CID:111413431)
Hello Jef
Thank you for your answer. Now it's ok
Best regards and nice week
Rocchino
(CID:111413763)
You are most welcome, Rocchino
wishing you a great week ahead,
Kind regards
(CID:111413765)
Posted: 2020-07-03 12:44 PM . Last Modified: 2024-04-08 01:50 AM
How to use cages in data center
(CID:111413448)
Posted: 2020-07-03 12:44 PM . Last Modified: 2023-10-22 04:42 AM
