Posted: 2020-07-03 12:43 PM . Last Modified: 2024-04-08 01:51 AM
Good day Can someone please help me with the DDF for a PM 5500 communicated via Modbus to the DCE
(CID:111413114)
Hi Omar,
Can you please be a little more specific? If you need a DDF, you can find them by going to the top menu of this page and choosing "Device Support". It may or may not be under the "more" menu. If there is a DDF available it should be there, if not you can request one.
If you already have a DDF and you are having issues with it, what issues are you having?Do you need help installing it? Are you unable to discover a device using the DDF? Are the values not showing properly?
Steve
(CID:111413131)
Posted: 2020-07-03 12:43 PM . Last Modified: 2023-10-22 01:47 AM
