Posted: 2020-07-02 05:00 PM . Last Modified: 2024-04-09 02:37 AM
What is the best way to manage the netbotz sensors with DCE? Actually I create a virtual sensor for each netbotz sensor and then I create a DCE threshold of this virtual sensor? It's that correct or there is a best way?
Best regards,
Enric Climent
(CID:103586334)
Hi Enric,
The NetBotz devices themselves are responsible for the alerting of the NetBotz sensors. This was by design since the old NetBotz Central. If Central went down, the device could still alert. You can also configure NetBotz thresholds and alerting through DCE's Device->NetBotz Appliance Configuration menu.
If you need to have DCE alert for these sensors for some reason, the only way to do this would be to create virtual sensors at this time.
Steve
(CID:103586340)
Posted: 2020-07-02 05:00 PM . Last Modified: 2024-04-09 02:36 AM
Thanks Steven,
I'm using the virtual sensors for DCE alerts.
Enric Climent
(CID:103586363)
Posted: 2020-07-02 05:00 PM . Last Modified: 2023-10-31 11:21 PM
