Posted: 2020-07-02 05:48 PM . Last Modified: 2024-04-09 02:11 AM
We are working in a integration project using the ETL and I would like to find a high ETL expert to make a conference call tomorrow morning and discuss some doubts we have.
(CID:104175160)
Posted: 2020-07-02 05:49 PM . Last Modified: 2024-04-09 02:11 AM
Hi Enric, I will try to find someone to help you out, but would you mind to share your doubts with us - there might be useful for Community as well 🙂 thanks.
(CID:104175186)
Hi Jef,
Here are our doubts:
Staging and export databases flow
How to modify current assets in SWO
How to change location of SWO assets
How to create new assets
How to change current network connections
Enric
(CID:104175207)
Hi Enric, reaching out to your local sales channel is what I would recommend.
(CID:104175266)
Hi Ajay,
I'm looking for a high ETL expert and I think it's better to talk with a devoloper in Kolding. My local sales channel hasn't any contact in Spain.
Enric
(CID:104188946)
Hi Enric,
I guess I might be able to help.
Staging and export databases flow: you can find explanations here: ETL - Extract Transform Load
How to modify current assets in SWO: our ETL platform does not allow modifications on assets but instead we can push new data to assets (power measurements, custom properties...etc)
How to change location of SWO assets: The only way to change the location of a device is via the DCO UI
How to create new assets: Same as previous question
How to change current network connections: Add, change or deletion of network connections is possible using our ETL architecture. If you have development skills the documentation linked above should be enough. If that's not the case please explain in details what information is missing.
Guillaume
(CID:104188975)
Posted: 2020-07-02 05:49 PM . Last Modified: 2023-10-31 11:20 PM
