Posted: 2020-07-02 05:49 PM . Last Modified: 2024-04-09 02:11 AM
I am using netbotz rack monitor NBRK0450. By default sensors temperature are in Fahrenheit and i want to see in Degree. Please advise. Secondly I am using camera pod CP160 (NBPD0160) by default approximately 16 feet USB cable and i want to extend camera 60 feet far. So can I extend its USB cable to 60 feet?
Mukhtar
(CID:104175219)
Hi Mukhtar,
1) In order to change the measurement from F to C on the NetBotz Advanced View and Basic View (web view), you should simply need to change the region and locale settings on your local computer. software reads the locale information from your computer (as set under Windows Control Panel) and uses that to determine the formatting options, so that each user may have their own preferences for viewing the sensor readings. Try changing the locale on our computer to something like English (UK). You will need to restart the NetBotz Adanced View software and then it should be displaying in Celsius.
2) The maximum length is 80 feet with a repeater or extender every 15 feet to boost the signal.
(APC NetBotz NBAC0213P USB Data Transfer Cable - 16.40 ft)
Let us know if you have any further problems!
Best Regards,
Rana Ajmal
(CID:104175226)
Posted: 2020-07-02 05:50 PM . Last Modified: 2024-04-09 02:11 AM
Thank You Ajmal. Usefull info.
(CID:104175228)
Posted: 2020-07-02 05:50 PM . Last Modified: 2023-10-31 10:58 PM
