installing Portal on RHEL
  • EcoStruxure IT forum
  • installing Portal on RHEL
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:41 PM . Last Modified: ‎2024-04-09 01:22 AM
657
Dear guys,
Could you validate Portal 1..3.2 can intall on RHEL 6 64 bits kernel version 2.6.32-504
There is any special consideration to do it?
Best regards,
Enric Climent
(CID:105461139)
  • Portal
Hi Enric,
Sometime ago we tested the portal installation on a similar RHEL 6 64 bits server (kernel 2.6.32-279), but a successful installation would require subscription to RedHat so that we can get packages during the installation.
Hope this helps,
Kind regards
(CID:105461184)
Enric,
I personally installed/setup Portal v1.3.2 on the simple physical server with CentOS 6.6 x64: I can confirm, that any special settings/nuances it isn't necessary to carry out/do.
With best regards.
(CID:105461164)
Hi Enric,
Hope this helps,
Kind regards
(CID:105461184)
Posted: ‎2020-07-02 10:41 PM . Last Modified: ‎2023-10-31 11:10 PM
