Posted: 2020-07-03 07:20 AM . Last Modified: 2024-04-08 04:13 AM
(CID:109447216)
Hi Fabrice,
Please check out k-base FA299535. This document outlines creation and management (including deleting) custom properties.
Steve
(CID:109447220)
Posted: 2020-07-03 07:21 AM . Last Modified: 2024-04-08 04:13 AM
Merci pour votre réponse, mon problème est maintenant réglé.
(CID:109447247)
Je suis très content de constater la rapidité et la qualité des réponse de votre équipe.
(CID:109447552)
Right click on the device and then choose "Open Custom Properties Editor" which will open the editor tab at the bottom of the DCE window. Then click the value (property) that you want to remove and erase it or change its value to what you need. You can only do this for custom property values you created not normal/default property values.
Edit. See Steven Marchetti's reply for a full overview
(CID:109447221)
Merci, Steven Marchetti a déjà répondu à ma demande
(CID:109447248)
Posted: 2020-07-03 07:21 AM . Last Modified: 2023-10-22 04:38 AM
