Posted: 2020-07-03 08:57 AM . Last Modified: 2024-04-08 03:42 AM
Hi team:
I need to get the temperature data and the power consumption of a server (see the pic) , can i get these data using API? I read the document of the RESTful API and didn't find anything useful about it, is the SOAP API available? can I use SOAP API catch the data? if it can be , how should I do?
Looking forward to your reply.
Best Regards.
(CID:110007762)
I don't have access to a system where I can test this currently but I think using the GET /assets/{asset-id}/devices operation might return the information. The information might be available in the properties.
(CID:110007907)
Hi Ren
How do you get the temperature and power data into Data Center Operations? Is it through ITO?
I just checked quickly with another of the developers before leaving, and we could get both power data and temperature data out through the REST web services for an ITOServerAsset. Other systems might also work, but I didn't have time to test.
I can't see the picture you mention.
(Also the SOAP API is not intended for custom use.)
Best,
Niels
(CID:110007803)
thanks for your reply.
(CID:110007913)
(CID:110007907)
Thanks for your reply, it helps me a lot.
(CID:110007914)
Posted: 2020-07-03 08:57 AM . Last Modified: 2023-10-22 04:38 AM
