energy efficiency Problem in 8.0.2
  • energy efficiency Problem in 8.0.2
129
72
Posted: ‎2020-07-03 08:57 AM . Last Modified: ‎2024-04-08 03:42 AM
561
Hello All
I configured the exactly same EE System in 7.5.0 and 8.0.2
In 7.5.0 it shows a Value for PUE
In 8.0.2 it shows no Value for PUE but also no error
Both systems are running now about 2 Weeks.
Are there any known issues for EE on 8.0.2?
BR
Patrick
(CID:110007776)
  • Data Center Operation
Posted: ‎2020-07-03 08:58 AM . Last Modified: ‎2024-04-08 03:42 AM
561
Hi Patrick,
I guess there might be basically some configuration hiccups, that's preventing your PUE calculations.
I've done some tests recently by using our live data center, this was to compare the same setup that is configured on DCO 7.5, and then restoring it's backup on a 8.0.2.
Both 7.5 and 8.0.2 are currently running the same setup - as illustrated:
1. both 7.5 and 8.0.2 is displaying the same PUE.
2. but the Scripts 'folders' seems to be duplicated, apparently the number of the duplication is proportional to the number of scripted sensors. For example (highlighted in 8.0.2 illustrated image)  if a folder contains 9 scripted sensors then it (folder) would be duplicated 9 times. Problem could be noticeable if user(s) should modify a random/different "duplicated" folder (otherwise PUE calculations seems to be okay if nothing is changed). However this has been logged as a software bug, which is expected to be fixed in the next release.
note: These duplication's seems to be a user interface issue, the virtual devices are not duplicated in the database! users should avoid deleting any duplicates.
Kind regards
(CID:110007989)
This may be one problem because i deleted some of the duplicates. I will try to setup again and will get back to you. Thanks for your feedback
(CID:110008065)
Posted: ‎2020-07-03 08:58 AM . Last Modified: ‎2023-10-22 04:33 AM
