Posted: 2020-07-02 05:57 PM . Last Modified: 2024-04-09 02:08 AM
Our customer is using AP7723 devices but I cannot configure it in DCO.
The device hasn't a power section on his properties and also power dependency. How can connect this device to the power source and to the other devices?
Enric
(CID:104188961)
Hi Enric,
Rack mounted transfer switches is unfortunately not support in Data Center Operation.
Only floor mounted ATS's are supported.
Jesper
(CID:104188966)
Thanks Jesper,
Have you plans to support it in future version?
Could you tell me any ATS reference to simulate it?
Enric
(CID:104188970)
Posted: 2020-07-02 05:58 PM . Last Modified: 2024-04-09 02:08 AM
Hi Enric, You are not the only one who have asked questions about the Rack ATS. So we are aware of the request, but I can not speak to when or if it is going to be implemented in Data Center Operation. The generic floormount ATS should work for simulation, but you will of cause not be able to place it in a rack. Thanks Jesper
(CID:104188971)
Posted: 2020-07-02 05:58 PM . Last Modified: 2023-10-31 11:04 PM
