Posted: 2020-07-02 05:58 PM . Last Modified: 2024-04-09 02:08 AM
Dear experts,
We had a AP9465 the status indicator LEC amber is blinking, I check the doc, it says the system has detected an error, but what kind of error it is and how to solve it ?
We checked the DCE , no alarms shows.
thanks!
(CID:104188982)
Posted: 2020-07-02 05:58 PM . Last Modified: 2024-04-09 02:07 AM
Hi Peter,
The AP9465 is based on a Dell server. Please provide the Dell service tag, the MAC address of the server, and the Dell service tag to your local APC / Schneider tech support. If it's under warranty, they should be able to assist you with correcting hardware issues / replacement if necessary. Your server is likely a Dell R200 or R210 but without that data (and I wouldn't want you to provide it on an open forum) I can not say with any certainty. There is also a display on the server and when there is an error, this display will usually show an error code which also may assist in any hardware troubleshooting.
Steve
(CID:104189019)
Can you please provide the capturelogs to diagnose the errors? To gather the needed logs please browse to http://
(CID:104188985)
Hi Peter,
Steve
(CID:104189019)
Posted: 2020-07-02 05:58 PM . Last Modified: 2023-10-31 10:15 PM
