How to reduce DCO configure backup file size?
  • EcoStruxure IT forum
  • How to reduce DCO configure backup file size?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 05:58 PM . Last Modified: ‎2024-04-09 02:07 AM
690
We have a standard demo server configure that we use to replicate to a few other servers for customer demos.  We found that the DCO backup file size is a little too big (around 730M) to copy around easily.  I deleted 95% of the rooms and folders, left only one data center in the configure.  I saved the change and then cleared all capacity history using the preference setting.   I then used "service operations purge" command to purge all log files.   I used "backup now" from the Admin UI to create a new backup file, and noticed that the backup file size is reduced only a few mega, nothing major changed.  Is there anyway to reduce the 730M backup file to <10M?  Why does it still have so much data with only one data center left in the configure?
(CID:104863287)
  • Data Center Operation
If you share the backup, we can have a look. Off the top of my head, the solution may include a lot of audit log data.
Update 2015-11-25 15:18: After investigating the actual data, it turned out to be true that the audit log data takes up a significant amount of space. Additionally, the e2m database is the same size as the isxo database so that is also contributing a lot to the total size of the backup.
(CID:104863300)
Posted: ‎2020-07-02 05:59 PM . Last Modified: ‎2023-10-31 11:06 PM
