how can chage background image DCO?
  • EcoStruxure IT forum
  • how can chage background image DCO?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 08:49 AM . Last Modified: ‎2024-04-08 03:44 AM
998
I'am trying to change background image, but i recive a error and can't change, How can resolve
(CID:110007461)
  • Data Center Operation
Replies 7
Hi Miguel, I was wondering perhaps it contains unsupported elements, would you mind to share it with me (off-line) so I can test it locally, thanks. Kind regards
(CID:110007475)
Posted: ‎2020-07-03 08:50 AM . Last Modified: ‎2024-04-08 03:44 AM
I try to put a .jpg or .dwg but i have no option. How can share with you?
(CID:110007483)
Hi Miguel, Please check your email, you might want to reply with your attached background image (dwg format!), thanks. Kind regards
(CID:110007486)
998
Hi Miguel,
Many thanks for sharing the image with me, I've tried it locally and it seems the CAD drawing is "unitless".  Displayed as a notification (please see the following capture), "Unitless CAD drawing cannot be imported. Please specify a unit of measurement, eg. feet or millimeters in the CAD file and import again."
We cannot import unit-less AutoCad files! When a drawing is unit-less, it means we do not know the units of the measurements - the dwg drawing must have measurement units (such as mm) specified to allow import drawing at correct scale.
Kind regards
(CID:110007497)
Jef i have no opcion to input any file neither dwg or jpg, only appear background setting and no more??
(CID:110007506)
Hi Miguel, The drawing itself needs to be "corrected" in AutoCAD, see for example the following video, which illustrates working with units in AutoCAD: https://www.youtube.com/watch?v=dCTO6Gmi9n0&feature=youtu.be Hope this helps, Kind regards
(CID:110007507)
Posted: ‎2020-07-03 08:50 AM . Last Modified: ‎2023-10-22 04:35 AM
