is there any way DCE can power a alarm beacon?
  • is there any way DCE can power a alarm beacon?
127
65
Posted: ‎2020-07-03 08:49 AM . Last Modified: ‎2024-04-08 03:45 AM
742
is there a way to power an alarm beacon through DCE?
(CID:110007458)
Replies 5
741
Hi Terrence,
DCE doesn't have any way to drive physical automation. You would need something else that would get a trap or mail from DCE to cause such an alert from DCE specifically.
As as you may already know, NetBotz appliances are capable of some basic monitoring and can drive physical automation like a beacon. Sadly, it does not work in conjunction with DCE alerts.
Steve
(CID:110007463)
thanks steven for the info.
(CID:110007464)
Posted: ‎2020-07-03 08:49 AM . Last Modified: ‎2024-04-08 03:44 AM
Yes.
(CID:110007468)
Dear Terrence,
I am not sure if this can help. DCE has got an option of playing a sound on the PC in which the DCE client is installed. Please check this option. PC can be connected to high volume speaker if the Customer wants to know to get sound notification whenever there is an alarm in the devices.
Bala
(CID:110007568)
Posted: ‎2020-07-03 08:49 AM . Last Modified: ‎2023-10-22 04:40 AM
