Best Way To Model A Device With A Direct Power Feed
  • EcoStruxure IT forum
  • Best Way To Model A Device With A Direct Power Feed
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 08:50 AM . Last Modified: ‎2024-04-08 03:44 AM
733
With the recent upgrade to v8 what is the best way to model a rack that has a device connected directly to it's own breaker and not via a rack mounted PDU (rPDUs)?
For example I have a rack with servers and a blade chassis in.  The servers are connected to the two rPDUs (A and B)  whilst the chassis is connected directly to a breaker.  If I put another set of rPDUs in I would get double the potential capacity on the rack overlay which would distort planning.
(CID:110007526)
  • Data Center Operation
Replies 5
733
Hi James,
Unfortunately currently it is not possible/supported (in DCO) to model rack mounted devices that can be power-cabled from another source than racks own pdus. Hopefully it's okay with you if I go ahead and capture this as a feature request, eg. feature for connecting a rack-mounted device(s) directly to a breaker out side the rack.
Kind regards
(CID:110007905)
Posted: ‎2020-07-03 08:51 AM . Last Modified: ‎2024-04-08 03:44 AM
Jef Faridi PLease add this as a feature request. Is there any advice from Schnieder on how best to model this situation? I can't really see another way other than adding a new set of PDUs to the rack.
(CID:110007921)
734
If you use the RackPDU workaround, then you can achieve correct remaining capacity of the rack by setting a design limit on the additional RackPDU(s) matching the estimated load of the connected server, the only down side is that the total power limit on the rack is too high.
Regards
Gert
PS: you find the design limit setting In the power property page of RackPDU itself (i.e. not the rack property page).
(CID:110008088)
Gert Lehmann Thanks, I'll give it a go.
(CID:110008505)
Posted: ‎2020-07-03 08:51 AM . Last Modified: ‎2023-10-20 05:03 AM
