Posted: 2020-07-03 08:51 AM . Last Modified: 2024-04-08 03:44 AM
Hi team:
I'm using the DCO offline demo 8.0 to do development, I want to get information of the datacenter such as assets of customer , display of the sensors in the rack...which I can see in the client, when I use https://
such as I want to see the assets of a customer, I need to fill the blank in the red retc, but how can i get or set the id? I tried username but the response is wrong. In other api asset-id,room-id...are needed,where can i find the id? Is there some examples for the using of api? I'm a newbie.
Looking forward to your answer.
(CID:110007532)
Hi Ren
Under the customer webservice, please take a look at the first GET method. The method gets all the customers the current user has access to. In the response you can then see the customer-id - which is typically a number.
An example reply:
[ { "id": "110", "company": "Some company name", "department": "110", "customerType": "EXTERNAL_CUSTOMER", "contact": null, "phoneNumber": null, "tenantPortalState": "NOT_ACTIVATED", "technicalContact": { "name": null, "email": null } } ]
So here the customer-id is 110.
Hope this helps.
Best,
Niels
(CID:110007542)
Hi Ren
An example reply:
Hope this helps.
Best,
Niels
(CID:110007542)
Thanks for your answer, it helps me a lot. I have another question, can I get the detail information of the server in the DC, such as the temperature & the power consumption of a server ? if it can be, what should i do? hoping your answer. Best,
(CID:110007618)
Can i got these information from the RESTful API ? if not ,what can i do? Please show me an example,thank you. Best Regards.
(CID:110007620)
Posted: 2020-07-03 08:52 AM . Last Modified: 2024-04-08 03:44 AM
Hi Ren, sorry I didn't see the comments here. Will answer you in the new question you posted.
(CID:110007801)
Here is a video tutorial Introduction to REST API
To get 'customer-id' you could use GET customers, which will list all customers accessible to the current user.
https://dcimsupport.apc.com/DCOAPIdoc/#!/customers/getCustomers
(CID:110007548)
Posted: 2020-07-03 08:52 AM . Last Modified: 2024-04-08 03:43 AM
Thanks for your answer, it helps me a lot. I have another question, can I get the detail information of the server in the DC, such as the temperature & the power consumption of a server ? if it can be, what should i do? Are these information gotten from the restful api ? Please show me an example, thanks. hoping your answer. Best,
(CID:110007619)
To get the ids required by specific operations you first need to query the operations that provide the required ids.
You can get the customer-id by querying the /customers GET operation.
The asset-id and room-id you can get from the /asset GET operation or the /assets/search GET operation.
The response from the queries depends on your permissions.
(CID:110007549)
Posted: 2020-07-03 08:52 AM . Last Modified: 2023-10-22 02:36 AM
