doc rest api _ asset creation in rack
  • EcoStruxure IT forum
  • doc rest api _ asset creation in rack
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:46 PM . Last Modified: ‎2024-04-05 12:27 AM
905
I'm trying to create this kind of server:
"type": "server-genome", "id": "ddbfb9ba-0dfb-4406-86c2-a5fae330d12d", "description": "Dell PowerEdge R720", "manufacturer": "Dell", "partNumber": null, "modelName": "PowerEdge R720", "width": 444, "height": 89, "depth": 723, "weight": 29166, "mountTypes": [ "RACK_MOUNTABLE" ], "unitHeight": 2, "nameplatePowerDraw": 1100
in a generic rack:
"type": "rack", "parentId": "54692dd1-1444-4068-b2f3-17e8183e9d23", "children": [], "navigationPath": null, "customProperties": null, "customPropertyTemplates": null, "accessType": "EDIT", "parentType": "storage", "name": "", "installDate": 1521812796923, "shape": [ { "x": 0, "y": 0 }, { "x": 600, "y": 0 }, { "x": 600, "y": 300 }, { "x": 0, "y": 300 }, { "x": 0, "y": 0 } ], "clearance": null, "positionTopLeftX": 0, "positionTopLeftY": 0, "orientation": 0, "cageId": null, "deviceLinks": null, "width": 600, "depth": 300, "barcode": null, "serialNumber": null, "modelName": "Generic Rack", "manufacturer": "Generic", "partNumber": "GEN_RACK", "partNumberId": -308, "weight": 10000, "description": "", "height": 300, "availableUHeight": 6, "maxWeight": 15000, "ductHeight": 0, "ductToCeiling": false, "designPowerLimit": null, "floorMounted": {}, "positionsOrderFromBottomToTop": true, "positionsCountedFromZeroIndex": false, "id": "94fa783e-ddca-4739-93c6-1bc7060e5deb", "stage": "EXISTING"
but this is the response:
 Adding assets to this asset is not supported
Could you give me any hint?
thanks in advance
(CID:129412183)
  • Data Center Operation
Replies 7
905
Hi Lucama,
Seems to be a mis-configuration issue, as illustrated in the asset-id field insert the id of the rack, and in the assetCreationV0 filed, insert the id of server, and also make sure the "rackMountPostion" (such as FRONT_MOUNTED) and "uPosition" is defined:
It worked for me without any problem - I could easily add a server into a rack (located in a datacenter and/or in a storage room).
Kind regards
(CID:129412239)
more or less is what I'm doing.
where asset-id is id of my rack, while in genomeId is the ho this genome:
    "partNumber": null,
    "width": 444,
    "height": 89,
    "depth": 723,
    "weight": 29166,
    "mountTypes": [
      "RACK_MOUNTABLE"
    "unitHeight": 2,
and response il always
{ "code": 100108, "message": "Adding assets to this asset is not supported", "details": "94fa783e-ddca-4739-93c6-1bc7060e5deb" }
thanks
(CID:129412717)
Hi Lucama,
Issue seems to be the uPosition settings:
You need to define a non-zero uPosition number when adding a front mounted server.
Kind regards
(CID:129412728)
905
Just looking at the rack and server size, could be because of the mismatch of rack and server depth:
The rack depth is depth": 300
The server depth is depth": 723,
Perhaps try with a rack that has more depth?
(CID:129412659)
ok, I've tried to add same server in another type of rack,
{ "type": "rack", "parentId": "54692dd1-1444-4068-b2f3-17e8183e9d23", "children": [], "navigationPath": null, "customProperties": null, "customPropertyTemplates": null, "accessType": "EDIT", "parentType": "storage", "name": "", "installDate": 1522305173854, "shape": [ { "x": 0, "y": 0 }, { "x": 600, "y": 0 }, { "x": 600, "y": 1070 }, { "x": 0, "y": 1070 }, { "x": 0, "y": 0 } ], "clearance": null, "positionTopLeftX": 0, "positionTopLeftY": 0, "orientation": 0, "cageId": null, "deviceLinks": null, "width": 600, "depth": 1070, "barcode": null, "serialNumber": null, "modelName": "Netshelter SX 42u 600mm Wide X 1070mm Deep Enclosure With Sides Black", "manufacturer": "APC", "partNumber": "AR3100", "partNumberId": -182, "weight": 125000, "description": "APC Netshelter SX 42u 600mm Wide X 1070mm Deep Enclosure With Sides Black", "height": 1990, "availableUHeight": 42, "maxWeight": 1363000, "ductHeight": 0, "ductToCeiling": false, "designPowerLimit": null, "floorMounted": {}, "positionsOrderFromBottomToTop": true, "positionsCountedFromZeroIndex": false, "id": "77e91c88-96f7-47e1-b2bb-4e4b6c386619", "stage": "EXISTING" }
but I've same result.
Unfortunately is a generic error, so I can't immediatly find  the root error cause
thanks
(CID:129413295)
Just sanity check, can you confirm on Uposition settings per Jef Faridi's comment above?
e.g use "uPosition":1 instead of "uPosition":0
Your rack counted U space from position 1, based on:
A screen shot of your Post parameters will help.
(CID:129413992)
Posted: ‎2020-07-04 03:46 PM . Last Modified: ‎2023-10-22 04:32 AM
