device power inlets showing "Not connected" on DCO 8.2.11 web client
  • EcoStruxure IT forum
  • device power inlets showing "Not connected" on DCO 8.2.11 web client
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-06 01:20 AM . Last Modified: ‎2024-04-02 11:15 PM
1094
On DCO web client, 8.2.11, device power inlets show "Not connected" while the truth is that they are. However, the status would be corrected after refreshing the web client. It happens time to time, which is causing operation inconvenience.
Please see an example in the screenshot.
(CID:154404888)
  • Data Center Operation
Hi Yilai,
Can I ask for the following data (to be provided via the secure site):
1- copy of the latest backup file (from the 8.2.11 setup)
2- server logs
3- do you/users see the issue with certain device? in a certain room?
4- how often do you/users see the issue?
5- issue being seen by certain user(s)?
6- which web browser are you/users using?
Kind regards
(CID:154405061)
Hi Jef,
1 - done - power_connection_issue.tar.gz
2 - done - power_connection_issue.zip
3 - not that i know of, it seems to be random
4 - not quite often, but often enough to be disturbing
5 - for now, only one user reported such issue, a couple of times already since last November or so. i randomly checked some devices myself, and was able to see the same issue - not many, one or two devices out of a couple of racks that i randomly checked
6 - google chrome, we are all using the same version across the firm - Version 79.0.3945.117 (Official Build) (32-bit)
Something that i found, you may confirm yourself, one refresh seems to "fix" the whole rack, if there are more than one device having such issue.
(CID:154405291)
Posted: ‎2020-07-06 01:20 AM . Last Modified: ‎2023-10-22 04:31 AM
