Posted: 2020-07-04 03:56 PM . Last Modified: 2024-04-05 12:25 AM
for some reason i have a network connection that i cant delete.
I can see the connection at the "network cable browser" but not on the map.
When i enter the connection properties i get a "The currently displayed page contains invalid values" error
(CID:129413299)
Posted: 2020-07-04 03:58 PM . Last Modified: 2024-04-05 12:24 AM
Hi Eitan,
The solution will be specific to your setup and I have reached out to you per e-mail.
(CID:130681249)
Posted: 2020-07-04 03:57 PM . Last Modified: 2024-04-05 12:24 AM
Hi Eitan Nachman, thanks for posting. Let's hope you find your answer here.
Kind regards Ditte
(CID:130091611)
Hi Eitan,
Wondering if it could be an option to delete the exiting model (server/switch/pp) and re-add it and then do the network connections.
I can also have a closer look at problem, if I may have a copy of the latest backup file. I will send you an invite from my =S= box shortly so the data (if you would) can be safely shared with me, thanks.
Kind regards
(CID:130092177)
The model is a optical patch panel. and i cant remove it because it has connection (the one i cant delete). very frustrating.
(CID:130092493)
Hi Eitan,
I've just resend invite (from my Schneider Electric box), so if you would share the data with me, then I will find out how we can resolve the issue. thanks.
Kind regards
(CID:130092866)
I uploaded the file.
(CID:130092927)
Hi Eitan,
I have re-checked my shared box folder (with you), it is still empty without any uploads,
Kind regards
(CID:130094020)
Please check now
(CID:130094102)
Hi Eitan,
Thanks, I will. Can you please also upload a screen capture illustrating the location of this patch panel and it's issue, thanks.
Kind regards
(CID:130094263)
I uploaded a capture.
(CID:130094266)
Thanks Eitan,
We are currently working on this and investigating the issue.
Kind regards
(CID:130095179)
Any news?
(CID:130096006)
Hi Eitan,
Sorry for the late update - we have located the cause of the problem, it appears that more than one connection is referencing to the same port(s). Our team is currently looking for a best possible solution that can be provided to you. Will get back to you as soon as we have the solution.
Kind regards
(CID:130096093)
Hi Eitan,
(CID:130681249)
Posted: 2020-07-04 03:58 PM . Last Modified: 2023-10-22 04:31 AM
