ddf files for Gateway Converters
  • EcoStruxure IT forum
  • ddf files for Gateway Converters
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:03 AM . Last Modified: ‎2024-04-05 03:07 AM
872
Dear Schneider Team.
We are currently using Babel Buster Gateway Converters to translate signals into SNMP.
Being that the use of Gateways requires Customization (basically assigning a signal to each OID), would there be a way for you to generate a ddf file if the mapping is provided?
Than you.
(CID:128065448)
  • DDF
872
Dear Banco Central Honduras,
Yes, of course it's possible: for this there is a special page Device Support on EcoStruxure IT. For example, a simple search for the key phrase "babel" produces the following result:
That is, at least the BabelBuster-MGE SP-PDU is already supported by DCE software. And by clicking on the button I WANT IT TOO within one business day you will be sent a web-link to download the DDF-file.
But if a 3-rd party device, for example, like your Babel Buster Gateway Converters is not yet supported by DCE software, then you can easily create a Device Request. How to correctly do this is well written in topic .
I hope this is what you need.
With respect.
(CID:128065479)
Replies 4
873
With respect.
(CID:128065479)
Thank you friend!
(CID:128065955)
Ok, thank you very much for the feedback 😀.
(CID:128065957)
Posted: ‎2020-07-04 04:03 AM . Last Modified: ‎2023-10-22 04:31 AM
