Posted: 2020-07-04 05:36 PM . Last Modified: 2024-04-04 11:52 PM
(CID:131960206)
Hi Kedibone,
Can you please add some description, screen captures, etc. to illustrate the issue, thanks.
Kind regards
(CID:131960234)
Hi Jef
I have attached screenshots of the errors i got,kindly find the document
Regards
Kedibone
(CID:131960258)
Hi Kedibone,
There are some screen captures, but no descriptions. Apparently, as notification says, either the address specified is an invalid address, or the connection timed out. Enter a valid IP address, or increase the connection timeout (default 10 seconds) and try again:
Kind regards
(CID:131960371)
Hi Jef
The IP address in this instance is not a problem, When i try to ping the IP address i can be to to ping it, also on the Web Client i can access with the IP Address. My main problem is when i start creating floor layouts/add groups and try to save the changes it does not save, and pops out the errors i have screenshot.
Kind Regards
(CID:131960388)
Hi Kedibone,
If you could provide the following data:
copy of the backup file
screen captures illustrating how to produce
client application.log file (located in C:\Users\
server logs (collected from server webmin interface > StruxureWare DC Operation > Download Log Files > Download log files)
then I will take look and see how it can be resolved.
I have send you an invite (from my =S= box) moment ago, so the data (if you would) could be shared safely with me, thanks.
Kind regards
(CID:131960624)
Posted: 2020-07-04 05:36 PM . Last Modified: 2023-10-22 04:31 AM
