dco rest api_ retry custom properties
  • EcoStruxure IT forum
  • dco rest api_ retry custom properties
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:57 AM . Last Modified: ‎2024-04-05 03:08 AM
1048
I'd like to retry asset custom properties using dco rest api.
in api GET /assets/{asset-id} there is  a parameter include that seems useful to retry custom properties:
  • custom_properties - adds information about custom properties to the returned assets (user related to customers can not request custom properties)
I'm trying this api, but I'm using wrong sintax.
Could give me some usage examples?
thanks in advance
(CID:128064732)
  • Data Center Operation
Thanks Rajesh,
It works.
(CID:129409904)
Replies 4
1048
Hi Lucama,
To retrieve Custom properties through GET /assets/{asset-id} method, you need to pass these two parameters
  1. asset_id -> asset id of the equipment(this can be fetched by searching for the equipment name in api method GET/assets/search)
  2. include -> custom_properties
By passing these two parameters to the api, you can retrieve Custom properties assigned to that asset
(CID:128064979)
In pictures
(CID:128064994)
Thanks Rajesh,
It works.
(CID:129409904)
Posted: ‎2020-07-04 03:57 AM . Last Modified: ‎2023-10-22 04:30 AM
