dashboard, local host 8080
  • EcoStruxure IT forum
  • dashboard, local host 8080
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:19 PM . Last Modified: ‎2024-04-08 01:59 AM
1133
I'm using local host 8080 for dashboard especially for PUE the value in DCO is accurate like 1.9 but when i add the portlet of PUE and set the same site on it the value shown there is wrong and its large in number like 9222,23333,720 and so on..   for the other sites  its accurate both in DCO and local host only 1 site is showing completely abnormal value in portal.
kindly suggest what to do ?
(CID:110792767)
  • Portal
Replies 5
Kindly check with the screen-shot also
(CID:110792789)
1131
Hi Wassem,
Many thanks for sharing the screen captures, I was wondering if there is a small chance that we are comparing two different PUE systems: "Evaluation of MLG" (DCO image) and "MLG1" (Portal image). The reason for my suspension is, because Portal can only display the data it is getting from the integrated system(s) ...
I can test your DCO backup (source of the "MLG1" setup) and see if it can be reproduced, then I would also need the evaluated values for the configured energy system (to be able to run the PUE calculations). Please let me know if I should send you an invite to my =S= box folder, thanks.
PS. (not related to this issue) if you are running the 8.0.0 setup, then it is highly recommended to upgrade to the latest version (currently DCO 8.0.3).
Kind regards
(CID:110793347)
HELLO JEF
Thanks for the reply
its one system only i have just kept the page name in portal MLG1 otherwise i have connected to the same site in DCO which is MLG.
and I'm running DCO 8.0.2 version.
yeah sure i need to solve this issue ASAP.
just tell me what i have to do ?
(CID:110793604)
Hi Wassem,
You are welcome, I have send you an inivite to my =S= box moment ago. Please share the following data with me: copy of the latest DCO backup file + the evaluated values for each script in "MLG" configuration, thanks.
By the way, what is the version of your Portal?
Kind regards
(CID:110793771)
Posted: ‎2020-07-03 12:20 PM . Last Modified: ‎2023-10-22 04:28 AM
