Posted: β2020-07-03 02:28 PM . Last Modified: β2024-04-08 01:18 AM
Dear expert,
One of our client is trying to using http post to export the device information. They have added several custom properties and found that in the xml file that HTTP post exported, they could not find these values. Other standard values, like device, type, location could be found.
My question is, could custom property also displayed in the xml generated by http post ? If no, does Web Service API support that function?
Best regards,
Ziqiang
(CID:115836732)
Hi Ziqiang,
There is no option in an HTTP post to specify additional information as there is in say a short e-mail message. Even with that alert, there is no macro to add custom properties. As for the web API, that is not a current feature. It is in the system as an enhancement request and I will add your post to that request.
Steve.
(CID:115836870)
Hi Ziqiang,
Steve.
(CID:115836870)
Posted: β2020-07-03 02:28 PM . Last Modified: β2023-10-22 04:28 AM
