Posted: 2020-07-05 09:59 PM . Last Modified: 2024-04-03 12:37 AM
Hello
I need the genome for a check point 22500.
23500-security-gateway-datasheet.pdf
Tks a lot
Rocchino
(CID:148766998)
Hi Rocchino,
Genome requests can be posted here: https://ddf.ecostruxureit.com/
For the time being as a workaround you might want to select a similar device (from Genome Library, such as Check Point 21400) and change its properties (in Genomes) so it can be used as your customized CheckPoint 23500.
Kind regards
(CID:148767016)
Posted: 2020-07-05 10:00 PM . Last Modified: 2023-10-22 04:27 AM
