Posted: 2020-07-02 03:11 PM . Last Modified: 2024-04-09 03:56 AM
Hi, I want to know how i can change the units of different sensors / devices. like centigrade instead of Fahrenheit or kW instead of W.
(CID:100340960)
Hi Shaf, thank you for posting. I'll see if I can find someone who can be of assistance here. @community - any ideas?
(CID:101027856)
Hi Shaf,
You can not change the kW to w without changing the DDF file. The DDF file determines if a value is shown in kW or w.
It is the local settings on your computer which determines if Expert should show Fahrenheit or Celsius.
See more here : Client Language Settings
Jesper
(CID:101027859)
Dear shaf alam
if you want to change value in web view data center expert the follow the steps listed below.
Also let me tell where you want to change the setting of Units in DSE client .
(CID:101613722)
Posted: 2020-07-02 03:11 PM . Last Modified: 2023-10-31 10:20 PM
