VIZOR - Port supported
  • VIZOR - Port supported
129
112
72
Posted: ‎2020-07-02 03:10 PM . Last Modified: ‎2024-04-09 03:56 AM
761
Dear Community,
We are testing VIZOR on iphone with DCO version 7.4.5. While testing with port 80 with the correct username and password, VIZOR has no problem displaying information from DCO itself. When we changing port 80 to 443, VIZOR shows error "A license for struxureware: capacity is needed to show capacity data" as shown below:
We later repeat the test with Andriod phone with the same version of DCO and port 443. The result is "Data not available – The server could not send the requested data. Try again." Port 80 is working with no issue.
Question:
  1. Is VIZOR supports the connection to DCO server through 443?
  2. If yes, what is the setup requirement? is any certificate needed?
    Thank you.
(CID:100340935)
  • Data Center Operation
Posted: ‎2020-07-02 03:11 PM . Last Modified: ‎2024-04-09 03:56 AM
761
Hi Law,
Vizor is not supporting port 443. Only port 80 can be used.
Some more information regarding Vizor including port configuration is found here: http://dcimsupport.apc.com/display/public/UAOp74/StruxureWare+Data+Center+Operation%3A+VIZOR
/Søren
(CID:101027885)
Replies 4
Hi Law, thank you for posting. Let's see if we can find someone, who can be of assistance here. @community - any ideas?
(CID:101027855)
762
Hi Law,
/Søren
(CID:101027885)
Hi Søren, Thanks for the reply!
(CID:101027893)
Posted: ‎2020-07-02 03:11 PM . Last Modified: ‎2023-10-31 11:41 PM
