cannot start SWO client with remote connection
  • EcoStruxure IT forum
  • cannot start SWO client with remote connection
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:55 PM . Last Modified: ‎2024-04-09 01:47 AM
766
I'm trying to connect to SWO with a remote connection and the client always is stopped when is loading base model services. How can I solve this problem?
Enric
(CID:105458472)
  • Data Center Operation
Replies 6
Hello Enric, Can you please provide the client and application logs to investigate your concern? Thanks Victor
(CID:105458474)
Hi Victor,
Where can I find the application logs? I cannot find them.
Enric
(CID:105458578)
Hello Enric, Both the client and application logs can be found in the directories below Client C:\Users\\.isxo\\Operations\.metadata Application C:\Users\\.isxo\\Operations\ Thanks Victor
(CID:105458573)
767
Hello Enric,
Based on the logs it would appear that the client is not able to download needed files from the server over the network.
!ENTRY com.apc.dcoverview 4 0 2015-12-17 16:02:28.427
!MESSAGE Error creating startup input (loading)
!STACK 0
com.apc.dsmf.client.webservices.event.QueueRemoteEventException: Unable to subscribe for events. This is likely due to a network issue.
I would recommend that the customer verify that the ports that are indicated in the URL below are open over VPN.
StruxureWare Data Center Operation Network Firewall Port Details
Victor
(CID:105458484)
Thanks Victor,
I'll talk with the customer to check that.
Enric
(CID:105458504)
Posted: ‎2020-07-02 06:56 PM . Last Modified: ‎2023-10-31 10:19 PM
