can't connect to DCO desktop client because of expired certificate
  • EcoStruxure IT forum
  • can't connect to DCO desktop client because of expired certificate
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 11:46 PM . Last Modified: ‎2024-04-04 02:27 AM
703
when i try to connect to DCO server with a desktop client ihave  a message:
a new licence must be granted before continue to use this extra module.
i'm on the way to register the server with  costumer licence
Thank you for your help
(CID:134033225)
  • Data Center Operation
703
Hi Jean-Claude,
Apparently the temporary license(s) has been expired - to resolve the issue you would need to add valid license key(s). I guess that was what you wanted to do, right?
In DCO 8.x the license administration can be done via the web-client, eg. log in via web-client and go to Administration > Licenses, and then add your license key(s).
That's it.
Kind regards
(CID:134033757)
Posted: ‎2020-07-04 11:46 PM . Last Modified: ‎2024-04-04 02:26 AM
Hi Jef
By the web-client, the problem was the same, because i needed to get the serial number to add valid licence. Finally a collegue told me to do it by the MAC-address instead of serial number.
And now things are going well, I registered my server and add valid licence.
Thanks for your help
Best Regards
(CID:134033862)
Posted: ‎2020-07-04 11:46 PM . Last Modified: ‎2023-10-22 04:26 AM
