Posted: 2020-07-03 06:02 PM . Last Modified: 2024-04-08 12:00 AM
Hot to configuration Action Beacon alarm on DCE?
(CID:122690864)
Hi kanit.s,
Can you clarify your question?
In general, as a rule, Alarm Beacon is physically connected to either a NetBotz-200/150 device (not appliance) or a NetBotz appliance (for example, NetBotz-450 or other). Therefore, the basic setting of the Alarm Beacon behavior is performed on these devices.
In the case of the NetBotz appliance, it sends alarms themselves, for example, when Alarm Beacon is turned on.
When use NetBotz-200/150 device (not appliance) then DCE-server can sends alarms (e-mail, for example) according to them, for example, when the Alarm Beacon is turned on (this behavior of the DCE-server can be easily changed).
With respect.
(CID:122691219)
Hi kanit.s, did you find an answer to your question?
Cheers,
Stine
(CID:126159503)
Hi Kanit,
I'm assuming that you've found a way to configure so I'm closing this question. If you still have this issue, please feel free to ask another question.
Stine
(CID:128750536)
Posted: 2020-07-03 06:02 PM . Last Modified: 2023-10-22 04:25 AM
