Which MAC use for a SWDCOCLUSTER-DIGI in a stand alone + DR setup?
  • EcoStruxure IT forum
  • Which MAC use for a SWDCOCLUSTER-DIGI in a stand alone + DR setup?
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 09:46 AM . Last Modified: ‎2024-04-08 03:13 AM
988
Hello community,
I´m installing a stand alone (no cluster) Struxureware Datacenter Operation Server with Capacity and Change licences for 200 Racks, also, it´s required a Disaster Recovery Server, I received from Schneider a SWDCOCLUSTER-DIGI License, but I need your help with this: When I activate the Operations Base License I saw a "warning" icon over the License Icon with the message: "This license is limited by another license" by the way I want to confirm which mac I need to use for redeem my one time pass code for the SWDCOCLUSTER-DIGI the Mac of the Operations Server or the Mac of the Disaster Recovery Server.
Other installation information:
Both servers are 8 cpu and 16GB, and will be installed in separate locations with a wan network latency from 10 to 20ms, bandwith 10Mbps, no VRRP (Virtual Route Redundancy Protocol) avaliable, virtualization: Vmware.
I really appreciate any guide in order to no made an error with the one time passcode redeem process.
Best regards,
Erlinson Bravo G.
(CID:110014349)
  • Data Center Operation
Posted: ‎2020-07-03 09:47 AM . Last Modified: ‎2024-04-08 03:13 AM
988
Hi ,
I think it would be good idea to register your "SWDCOCLUSTER-DIGI" license under the MAC of your Operations server, so all your DCO related license(s) would be collected/registered under the same MAC address.
Kind regards
(CID:110014571)
Replies 4
989
Hi ,
Kind regards
(CID:110014571)
Posted: ‎2020-07-03 09:49 AM . Last Modified: ‎2024-04-08 03:13 AM
Hello Mr. Faridi,
Thanks for answer, you´re right, when you allow a node connection (with the DR-Node_IP) you see a high availability license with 1/0 red numbers and a header message: "The license is exceeded. Please contact your system administrator" after see this message I redeem the one time pass code for the Digi license with the main DCO server´s mac and it was accepted by server.
Thank you very much for your support.
Best regards,
Erlinson Bravo G.
(CID:110015074)
You are most welcome,
Kind regards
(CID:110015080)
Posted: ‎2020-07-03 09:49 AM . Last Modified: ‎2023-10-22 04:20 AM
