AP9520T/TH Documentation
  • AP9520T/TH Documentation
126
65
Posted: ‎2020-07-03 09:46 AM . Last Modified: ‎2024-04-08 03:13 AM
942
I'm trying to find some documentation for the AP9520T/TH sensors but only able to find the installation sheet on the APC website.
Specifically, I'm after the DIP switch positions that specify the A-Link address of the device.
Could someone point me in the right direction?
(CID:110014183)
  • NetBotz
Replies 5
942
Hi David,
The install guide here does show how to set the addresses and how each dip switch configuration is set for a specific address:
It also states:
See the documentation provided with the monitoring device for A-Link addresses. Each sensor must be set with a unique A-Link address. Some addresses are reserved for use by the monitoring device. The addresses for sensors will vary depending on the monitoring device to which they are connected.
Most devices do not have a reserved ID. With what appliance do you plan to use these sensors?
Steve
(CID:110014191)
Hi Steve,
Thanks for the reply - these are on a NEtbotz 450
David
(CID:110014227)
942
Hi David,
The installation guide for the AP9520TH is now available in the PDF Library. You'll find guides for the NetBotz appliances there, too.
Best,
Jackie
(CID:110014280)
Thanks Jackie
(CID:110014768)
Posted: ‎2020-07-03 09:46 AM . Last Modified: ‎2023-10-20 04:56 AM
