Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Where can we download firmware catalog?
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • Where can we download firmware catalog?
126
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-03 01:38 AM . Last Modified: β€Ž2024-04-09 12:32 AM
1490
Hi Team!
Where I can find links for DCE firmware catalog?
It's absent on product support pages on apc.com.
Does that mean that offline mass upgrade is not supported now?
(CID:105470230)
1488
Hi Valentin,
I downloaded from the link I recently gave you and checked the gollowing directory:
StruxureWareDataCenterExpertFWCatalog.zip\NetBotzV3\
There is another folder marked \4_5_1_20151117_1714\
 I then checked one of my DCE servers for it's NetBotz , it's current application,
It appears to show the 4.5.1is unavailable however I have not yet added the catalog:
I then added the catalog from that link and the upgrade is available:
You are using the 2nd link I provided correct? The one from April 4th?
Steve
(CID:105470868)
Replies 7
1488
Hi Valentin,
You may have noticed changes in the APC web pages and I believe at least in part that is the reason it can not be found. In any case, I have informed product management about this issue so that they can work towards getting the official link back on the web page either under software downloads or on the product pages. IN the meantime, I have a box link that you can use. The latest catalog file is from December so if you had updated since then, you probably already have the most recent catalog. I have also asked that a new one be generated but I have not see that yet. Once it is created, I will put that on box as well if it is not available as it should be. Sorry for any inconvenience.
https://schneider-electric.box.com/s/sc2m2bns9lbq25ytzllpyftyuskpijei
Steve.
(CID:105470316)
Thank you Steve! There is no inconvenience at all πŸ™‚
(CID:105470343)
Hi Valentin, They made a new catalog over the weekend so while we're waiting for it to hit the web (hopefully), I thought I'd share it here: https://schneider-electric.box.com/s/1i3bqtgxmr8km7q66zpaayhak6y9gemy Let me know if you have any issues with it. Thanks, Steve
(CID:105470423)
Thank you Steve! By the way, Netbotz 4.5.1 firmware pack is absent too. Can you tell responsibile persons about it?
(CID:105470812)
1489
Hi Valentin,
Steve
(CID:105470868)
Posted: β€Ž2020-07-03 01:39 AM . Last Modified: β€Ž2024-04-09 12:32 AM
Sorry Steve! You are absolutely right. It's present in firmware catalog. I was incorrect in my comment! I mean that firmware files are absent on product support page at apc.com. Latest version on apc.com is 4.5.0
(CID:105470875)
Posted: β€Ž2020-07-03 01:39 AM . Last Modified: β€Ž2023-10-31 11:44 PM
