Posted: 2022-02-10 05:05 AM
Anybody have issues with load time upon initial startup for DCE? We experience up to 5min of load time before login screen appears.
Posted: 2024-05-03 04:11 AM
Hi @BrainyGravel,
I know that this post was some time ago, but wanted to get a reply out there in case others are running into the same issue and come across this post.
If DCE is running as virtual appliance (VM), please ensure that the system resources are at, or above, the recommended resources: https://community.se.com/t5/Data-Center-Expert-Virtual/DCE-sizing-guide/ta-p/446647
You can also check system performance (not boot time) to ensure that evaluate overall performance after boot: https://community.se.com/t5/Data-Center-Expert-Virtual/DCE-performance-troubleshooting-guide/ta-p/44...
I would also suggest that the DCE server come up to the most recently available version to see if there is any improvement over the boot time. Information on the most recent releases of DCE can be found: https://community.se.com/t5/Data-Center-Expert-release-notes/tkb-p/data-center-expert-release-notes
To receive software updates or further troubleshoot performance issues (as log files would be needed), please reach out to technical support.
Cory
