Posted: 2020-07-03 05:50 AM . Last Modified: 2024-04-08 11:13 PM
I have to upgrade Java on our Portal server,
what version is supported?
Martin
(CID:108824649)
Hi Martin,
I've been told that StruxureWare Portal should be used with its shipped java (that's been tested during the software development), I think the latest Portal (currently v1.3.3) is shipped with Java 7.
Kind regards
(CID:108824778)
Hi Martin,
Kind regards
(CID:108824778)
Hello Jef,
Thank you for the info, Having looked in to this a bit more after seeing your comment, the Java Version on my server is Version 7 update 79. Oracle are currently on Update 111.
Update 79 ran out of support April 2015.
Do you know if there is likely to be any upgrade to Java?
(CID:108824784)
Hi Martin, You are most welcome - as far as I know there is no java upgrade planed at the moment (I will share this with our team), thanks. Kind regards
(CID:108824819)
Hi Jef, I have another customer that needed an updated version of java 8. I can provide a list of vulnerabilities detected by their security software Rapid7 if that helps. If you need additional details let me know.
(CID:110004409)
also we were able to update to Java SE U80 if that helps anyone
(CID:110004410)
Hi Jef
Its that time of year again where we have to look at upgrading Java on the Portal server, Please can you advise what the latest version is which we should be using?
I have just upgraded the portal to version 1.3.7.
Martin
(CID:120817528)
Posted: 2020-07-03 05:50 AM . Last Modified: 2024-04-08 11:12 PM
Hi Martin,
I've been told that Portal supports the java that is basically shipped with. I understand you well, but unfortunately due to the Liferay version, Portal works best with its shipped Java. And as far as I know, there is no plans to update StruxureWare Portal to the latest Liferay platform for the time being.
Kind regards
(CID:120817691)
Posted: 2020-07-03 05:51 AM . Last Modified: 2023-10-31 11:42 PM
