DCO Connection Error
  • EcoStruxure IT forum
  • DCO Connection Error
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:48 AM . Last Modified: ‎2024-04-08 11:13 PM
1188
Dear Team,
I am having a connection error from one of my customer. I am able to ping the server but having the attached error's.  Also I am not able to reach webmin to collect the log files. Looking for advises.
Thanks in advance.
Best regards.
(CID:108824640)
  • Data Center Operation
Replies 8
Posted: ‎2020-07-03 05:49 AM . Last Modified: ‎2024-04-08 11:13 PM
1188
Hi Behram, If you are not able to reach the server via webmin, then it might be network related or perhaps 'DCO server' is not running (ping will only confirm that the host/server is alive/online, but it cannot say anything about its functionality/operation) ... Perhaps the server have been disconnected and reconnected, if so rebooting might be needed. Can you try from another workstation and see if you can reach the server both via webmin and ssh access (via Putty or similar tool). Is this a physical server or running on VM? (verify if the server is okay, you might see warnings on its console). Kind regards
(CID:108827834)
Hi Jef, Thanks a lot for your quick response. The setup is on VM and I just checked the SSH access and it is working fine. How can we test that server is working properly ? What kind of comment do we need? Server seems ok but still have the same error. Best regards
(CID:108827836)
Hi Behram, I would at least try "sudo service operations status", that would inform if the Operations is running. Did you try to test the connection (Webmin and/or dco client) from another workstation? Basically you would need to access the Webmin (try from different workstations "close" to server - excluding the network/routing issues), if not accessible, then ssh login, and "reboot". Please let me know how it goes, thanks Kind regards
(CID:108827838)
Hi Behram, I was wondering how it goes and if the issue is resolved? Kind regards
(CID:108827840)
Dear Jef, Sorry for my late response, but the customer is not reachable for last 2-3 weeks. The issue is still on going and even we do the reboot from vm consoles and etc. Having the same. By the we are not able to reach from putty from the client pc this an another interesting point. We are able to open the https://#dcoip/ but not able to go further. I am connected to customer via webex. Do you have time to take a look ? Best regards
(CID:108828407)
Hi Behram, No problem. I can take a look, please email me the webex link and phone no, thanks. Kind regards
(CID:108828412)
Hi Behram, Many thanks for the meting this morning - just a short note to share with you/community that basically the issue was/is disk space related (the current setup has too little disc capacity and is full). Customer will 'upgrade' the setup based on system recommendations (using at least 100 GB storage). It was suggested that they will go for the latest version (currently DCO 8.0.1). Kind regards
(CID:108828491)
Posted: ‎2020-07-03 05:49 AM . Last Modified: ‎2023-10-31 10:48 PM
