Posted: β2020-07-02 11:36 AM . Last Modified: β2024-04-10 12:12 AM
Now that the serial number field has been added as a static property, what is it's CI?
Example:
ci_model_name |
varchar(255) |
The equipment model information/name |
(CID:95355563)
Hi Sean,
The CI name is ci_serial_number
We will work on updating the export database table information documented ETL Export Databaseto reflect this as well.
(CID:95355617)
Hi Sean, thanks for posting. @community_members - your comments and answers are very welcome!
(CID:95355592)
Hi Sean,
(CID:95355617)
TY
(CID:95355696)
The ETL documentation has been update to reflect the latest ETL Export database http://dcimsupport.apc.com/display/DCIMDEVELOPER/ETL+Export+Database
(CID:96043024)
Posted: β2020-07-02 11:36 AM . Last Modified: β2023-10-31 11:42 PM
